pyronix alarm - wireless low batt
I would power cycle the control panel.
Have you changed the engineer restore in programming from anti code to user ?
The SMS server that the panel is using maybe shutdown. You need to check how it’s set up in ARC settings
Ok so I calculated that it’s actually day 180 today :(
So I shut down the alarm mcb (even though the alarm remained powered on - must have built in back up battery?)
Anyway - as I opened the alarm panel I get a text message?!?
“-D Alarm - Case Tamper “
So I’m guessing the number is still active!
Which is good news as I don’t need to change the sim I think….
But how strange that it didn’t send me a text when the alarm actually went off??
Normally I get one when I let it ring out as a test ….
What exactly in ARC settings should I check please can you advise?
I will try again tomorrow to let it ring out.
I can’t understand why it would send a tamper message but not the senses movement one?!?
I got the message :)
When testing I did on B (downstairs only). I needed to do on A (whole house)
My settings must be so that only get a text for A….
