Pyronix diallers help
13 May 2021
I have a pyronix euro V10 system.
It currently has a standard v2tel dialler.
I would like to add some form of digital access (for the app). I assume I have a choice of the LAN or a GSM/GPRS version.
As I understand it the LAN version will NOT dial out or alert in any way other than push notifications?
Is the GPRS/GSM version the same? Or will this do both SMS and dial out and allow app access via data?
Alternatively can the dialer also be kept so for instance LAN for connect/push and dialler for dialled alerts?
Are you sure it’s version 10 ? And it’s either an enforcer or euro 46 panel ? If so then you can add either a digi lan , digi WiFi xa or a gprs plus SIM card …all 3 give you access to your control panel with set / unset option …all 3 will send alerts to your mobile phone giving audible voice alerts ( if critical alerts are enabled on your phone ) even when on silent ..
All 3 services have an annual cost after the first year ..
Yep, euro46 v10
Ideally I'd like to be able to set/unset from my phone but also have other people be alerted to any alarm activations/if it goes off (dialled or sms'd not via push on an app which they wouldn't have)
Can the GPRS+ SIM work alongside the standard landline dialler?
Yes you can add a gprs module for app and keep the existing v2 dialler (as long as you have an analogue phone line)
