Hi
An observation that I would like to understand the logic of if anyone has the answer...
The PIR's around the house/garage are KX10DP-WE, I have left the jumpers so that the blue LED's flash when system is disarmed and motion is detected.
The flashing used to be minimal, almost like waking the PIR from sleep mode every now and then.
I have now changed the set up so that the garage (PIR) is armed whilst the rest of the house is disarmed, since changing the set up the house PIR's flash with every single movement made, why is this?
I know the simple solution is to change the jumpers so LED is off, I think if I do not do this the current flashing rate will have an impact on battery life!
Thanks in advance.
Thanks in advance.
