I've just set up a Euro76 control panel (with digi LAN fitted) and keypad on a bench before I replace my current system. I'm trying to get it programmed before installation.
I've linked all tamper circuits and zone inputs (with a small link wire), and assigned a user (with relevant access). Set the only keypad to work Areas (A,B,C,D)
All zones are set to "Intruder" except for Zone 1, which is set to "exit"
Area A = Full Set
Zones, 1 = front door, 2 = Bed1 PIR, 3 = Bed1 Window, 4 = Bed2 PIR, 5 = Kitchen PIR, 6 = Living PIR, 7 = Living Window, 8 = Dining PIR
Area B = Night Set
Zones, 1 = front door, 3 = Bed1 Window, 6 = Living PIR, 7 = Living Window, 8 = Dining PIR
(ground floor apartment, so no requirement to open the front door to leave)
When I do a Full set everything works as expect, if a zone is triggered the alarm sounds. Bonus!
First issue, when I do a Night set, the system arms straight away with no "leave via the exit route" message on the keypad.
If a zone is triggered, say Zone 3, nothing happens, no alarm sounds!
I do however get a push notification on the "HomeControl2.0" app telling me the zone has been triggered , but no sirens etc go off.....
The same occurs if I set up area C or D, everything arms, but no sirens etc go off when a active zone is triggered.
Second issue, if I do a Night set, the system arms straight away, which makes sense as there is no "exit zone" as I'm not going to open the front door to then close it to arms the system.
But, if I go to disarm the system once set, by entering the code, it then asks which area I want to set next, it doesn't disarm the Night set area
I'm assuming the system needs to see some form of "exit" in order to arm / disarm the system correctly in these Areas. If so, what do I set a zone to in order to achieve that?
Any suggestions would be greatly appreciated, I've installed Bosch and Siemens systems in the past, and haven't had these types of issues (plenty of other issues, but not these two)
Area A = Full Set
Area B = Night Set
