Pyronix fault
Move wiring to a different zone and see if goes O/C in diagnostics
Will try this too but on diagnostic its showing
When looking at the endstation zones on diagnostics, press yes, will let u scroll through the zones and show resistance values. Should be 2.2k/6.9k with lid on pir. Its showing F so is not seeing the correct resistance value. Move to another zone as the input may be faulty, can also try moving the yellow wire on the pir across 1 terminal to rule out device tamper switch, if that dont work will have to get the multimeter out
On diagnostic all I see is view psu which shows 13.4V and then view inputs where it shows F? Doesn’t let me scroll through
