the confusion comes from this possibly being HMO
If you are renting indivdual rooms in a house to people who are not related to each other then that house is a HMO
Indeed, as described there is no "possibly" about it - it is most definitely an HMO.
If you own and / or manage an HMO and do not comply with the regulations then you will be liable for some very hefty fines. One unhappy tenant reports the state of the house to the local council and if you have not complied with the regulations then you are in trouble.
Regulations on the property, regulations on it's management, regulations on the landlord - for a property this size, in many locations you will need a licence to run it.
im getting different views and answers from all over the place and the confusion comes from this possibly being HMO.
I'm not surprised. Different people will have their own "pet" technologies - while others will have hate the same thing. For example, try looking for mentions of "thermal store" in the plumbing section. You'll find a few mentions in favour, and a number of comments along the lines of "complete rubbish and I'd
never ever suggest one" - usually from the same people who think a combi is the best option for everyone
Part of your problem is that you haven't done all the investigations needed to answer the question - and electrics is only part of it. To start with, assuming that people will want to shower at the same time, do you have the water supply to cope ? So what pressure do you get from the mains ? And what happens to that pressure when you try and run 4, 5, 6 showers off it ?
If it isn't adequate, can you get it upgraded ? At a reasonable cost ?
You may find that you either have to downgrade your specs, or look at workarounds. One workaround may be to install a large buffer tank - but then you'll need pumps to re-pressurise the system. Or you may be able to just fit accumulators. I've stayed in a hotel where they've got this wrong - the showering experience "wasn't good".
So, you've worked out how to get the flow rate, now you need to heat it.
Forget about lecky. A half decent shower will pull 40A (or more), you've a 100A supply less other loads like washing machine, kettles, cookers, etc etc. Gas is 1/3 the cost.
But now you are back to supply capacity again - I bet you can't get enough gas out of the pipe to heat the water on demand. But you won't know unless you ask your supplier just how much you can get out.
So we're almost certainly into heat storage. You can have open vented cylinders (naff all pressure), unvented cylinders (need all the safety gear, regular servicing, restrictions on siting), thermal stores (my personal favourite) & heat banks. For the latter you have a choice of direct or indirect - indirect having better reheat capacity. To a certain extent you can trade off boiler capacity and stored water capacity - at one extreme you can have storage large enough to supply all reasonable shower requirements and take all day to reheat, at the other you can have small storage but need bigger boilers.
With thermal stores & heat banks you can also run the heating from them - avoids the issues trying to balance the incompatible characteristics of boilers (minimum/fixed flow rate) and heating systems (variable flow rates).
I'd go with a number of smaller boilers rather than one large one - that way a boiler failure (and they will fail sooner or later) won't leave you with nothing at all.
And with storage, you have the option of electric immersion heaters for backup. Potentially you can make these fairly powerful, especially if you use priority relays to turn some of them off when (eg) the oven is turned on. With a thermal store or heat bank, the immersion heaters can supply the heating as long as there's enough capacity - that's what I did in my rental flat, but the heating load is only about 2kW.
With multiple boilers, you can possibly leave out the immersion heaters - or at least keep them to a minimum.
So, has that given you enough to go on ?
