I am looking into the idea of a cinema room and I want to be able to turn off all of the devices in one go.
I want to be able to turn them off properly, rather than leave them all on standby, but I also want everything racked nicely and hidden away with tidy wiring.
It has been suggested to me that the best way for this to be done would be to have the bank of sockets all controlled by a contactor, then have one switch controlloing that.
I have got two questions -
1. What kind of switch would I need to use to control the contactor? Becasue the load required to control the contactor is relatively low, Is it simply a case of using a normal light switch, or would that not meet regs ?
It would be nice to have the controller switch on the wall next to the light switch, with them both looking the same.
2. Would it be a good idea (or simpler to wire) to have the cinema sockets wired up on their own MCB from the CU as well, and if so should it be a ring or radial circuit?
Don't worry - I am not going to do this work myself, I am just interested to know how all these things work, so that I know to get the right set up installed to meet my requirements.
Cheers
Gary
Cheers
Gary
