Just re read you post, can you not use the time clock to energise the coil and do away with the photcell? Less is best.
your right!!!Using a photocell in conjunction with a timeclock is a great idea. Lights always go off at the same time but come on when needed in respect to lighting levels which is great for winter as it gets darker earlier.
Can't see picture clearly as lost glasses, 13 & 14 are what's called auxillary contacts, used as hold on circuits for when you remove finger from the on button. Connect across 1 & 2, they are the contacts that have a higher current rating. Do you have 3 sets of contacts . A1 & A2, and 13 & 14 arrangement?
You are aware that the coil of the particular contactor you're using is 110v aren't you? It certainly appears to be with the minimal searching (fuelled with Vodka and Red Bull) I've carried out on your behalf.
No timer then? Lights come on at dusk and off at dawn?
What's the switchable rating of the photocell? Do you really need a contactor?
Sorry gary, if you read back you'll see what i was actually doing. No no timer thats too easy.
I have the load (lights) a switch (timeclock) and the supply. where do all the live and neutrals go in the contactor. the trerminals i have a 1, R1, R3, 3, 2 R2, R4, 4, 13no 21nc, a1, 14no, 22nc, a2 i don't think i will need all terminals as its only single phase. Can anyone help please, or have a simple diagram. Thanks
I must have misread your original post then!
