I doubt the problem is with the splashback not being square.
Most likely cupboards and worktop are not parallel as others said.
Easily fixed by adjusting wall units.
BTW, end decor panels must be installed after splashback.
And wall units are usually adjusted higher than final position to allow easy installation of splashback, then lowered with adjusting screws.
Just saying, it's not only the quartz fitters fault, the kitchen fitter should've known that he needed to come back to adjust wall units, notch and fit end panels.
