you are adjusting the miters on the angles
i am suggesting rather than adjust the bevel [lean ]on the saw further complicating the cut you just replicate this on the fence by packing
the problem you have you are altering the bevel and the angle if you are well versed then great otherwise you also need to adjust the bevel angle on the cutyou are adjusting the miters on the angles
Sorry to sound dumb but still cannot understand your method could i not just get the sliding bevel ,measure the angle ,use a protractor to find what degree the angle is ,then half it and ajust the bevel to that figure then mark it on the skirting board .Then use a sliding mitre saw set it to whatever degree i bisected ,say example 67 degrees ..Ajust the sliding mitre saw to 67 degrees and then cut it..Would this work ,yes or no .. surly i should be able to get the cut right.
Just seems i am going round in circles ,
zapper42 said:The bottom looked like a tent with i a big gap --
-- if the wall is out off plum vertically as it then requires correction on 2 directions at once --
Yep. First task when skirting out a room - take a club hammer and bolster to the splay....it is normal to knock off the plaster under the skirting line to allow the skirting to fit plumb.
