- Joined
- 7 Feb 2010
- Messages
- 3,009
- Reaction score
- 332
- Country
There should be a vapour barrier on the warm side of the insulation - that is, a plastic sheet between the plasterboard and the insulation. If you use Kingspan/Celotex and seal it properly (tape or expanding foam), the foil backing can provide the vapour barrier. That's how you stop warm moist air getting into the void. It's then a good idea to provide ventilation to the void from outside, so that any mosture that does get in there (from below or from leaks) can be dispersed.
Cheers
Richard
Cheers
Richard
