OK so big-all was the first to get it...... although second time round.big-all said:ok the level will fall as the displacement of the brick in the water is less than the weight it would displace when in the boat![]()
OK - what bearing does the mass of the article have on the volume of liguid it displaces?notb665 said:ninebob said:That can't be right, surely? What bearing does the weight of the article have on the volume of liquid it displaces?Thermo said:"a body immersed in water will displace a volume of fluid that weighs as much as the body would weigh in air"
You mean 'mass', right?
ban-all-sheds said:OK - what bearing does the mass of the article have on the volume of liguid it displaces?notb665 said:ninebob said:That can't be right, surely? What bearing does the weight of the article have on the volume of liquid it displaces?Thermo said:"a body immersed in water will displace a volume of fluid that weighs as much as the body would weigh in air"
(You mau assume that the article is not made of collapsed matter)
ban-all-sheds said:You mean density....
A buoyant object will displace whatever volume of water has the same mass as the object. Whilst in the boat the object is classed as buoyant.ban-all-sheds said:OK - what bearing does the mass of the article have on the volume of liguid it displaces?
gcol said:Hmmm. So we can assume that whatever fluid leaves the boat will be pretty much water so the level will be the same. If there's some sick, then it's about 50/50 - some floats and some mingles in with the water, so again the level will be the same. If it's a particularly good vindaloo then he may need to .... erm.... well go - assuming it's a proper vindaloo then it'll vapourise upon leaving his bum so the water level will rise.![]()
Jeeezus the dog's just farted.![]()
