Thanks - i just assumed that if EVERYTHING in the premises was switched off completely and the only consumption was these 16 machines (on a sub-meter), then the main and sub-meter readings should match??
Was waiting for a 'call an electrician' smarty pants to step in - there's no harm in acquiring knowledge beforehand so I know what the cheapest option is.
On the other hand, it doesn't do any harm to find out options beforehand. Especially if it's a small business and doesn't employ a sparky very often, it's hard to know if the sparky you are using is trustworthy. They may well trust the sparky they use, but if they have no knowledge of the subject, he could still be "padding the bill".
Put another way, how do they know they can trust the sparky they are using if they don't know enough to know if they can trust what he's telling them ?
EDIT: And not to mention, they may well have someone they've used before - but they do have a habit of retiring, packing in because they've had a better option, ... and then you have to find another sparky and it's back to square one.
On the other hand, it doesn't do any harm to find out options beforehand.how do they know they can trust the sparky they are using if they don't know enough to know if they can trust what he's telling them ?
