Racal Guardall RLC1 Control Unit
5 Jan 2008
Surrey
Can any one help me locate an installation and repair manual for this PIR Light Control unit?
Cover broken and the PIR lens is cracked. I need to replace both and need the original wiring details.
depends what your changing it for, some (gjd) detectors will work, most won`t but if i remember correctly (beige color control unit with slide switch?) its power, a trigger (yellow) and a hold off for daylight (blue) both positive applied
be simpler to replace the whole thing IMO
Hi Pheell - I have the same problem; needing to replace the external PIR for my LRC1. How did you solve the problem?
