monitorman you are overlooking the obvious.
lets say a person wants to follow your info, lets call that person Q (I just happened to have chosen Q at random, no other reason)
Q will have to find and buy an ultrasonic cleaner
Q will then have to read the instructions of said ultrasonic cleaner
Q will then have to read up on how to test / change RPY97 detecor IC (assuming by
IC you mean it is an Integrated Circuit) not to mention by a soldering iron etc to change said IC (i assume it is soldered in, all well and good if its in a socket)
Not looking good is it.
Q then has a problem and posts here for your guidance, Q will have to wait a minimum of 26 days for a reply from you. (its a shame, but you do post infrequently)
Monitorman, as before, i said
breezer said:
Monitorman, its nothing personal you understand, (no really, its not)
i still standby that.
I admire you for what you have done, but its of no real use, since what if you are wrong and the unit fails again, or what if you are right and something else fails?
racalites were known for their high failure rate, quite often due to corrosion. The latter units had two tiny holes in the bottom front to let water out, but this didn't seem to work too well either.
monitorman said:
"No, breezer, we are not going to agree on this, our philophy's are different, you are "Rip it out and replace with new" mine is "Fix it if I can".
Yes monitorman, that is true. Rip it out because:
new kit will have makers g'tee
i can sleep at night knowing kit is reliable
Customer is happy because they have new kit not a repair / bodge (I am not saying what you did is a bodge, just not a good repair since no where did you mention after removing the
monitorman said:
horrible slimy wax like stuff.
which you also blamed for the fault in the 2nd place (rightly or wrongly) you failed to mention any replacement so the unit will corode even quicker than they normally did.
its pointless flogging a dead horse, which is what you are doing. (trying to get a very old style of detector to work again)
If however, it was for your enjoyment / satisfaction to repair such a piece of junk then yes, i am happy you enjoyed it and got pleasure (No, really i am.)
But for the average joe bloggs, like Q, its a total waste of time, which is what i said in the first place.
Nail in the coffin time
now even you cannot buy, and install a new system for £60.
don't need to, you can use existing cables, but you can buy the kit starting at just under £60 (and i do mean Just)
google for GJD
and not forgetting if you want to buy stand alone pir / flood lights (which could be put on the existing mains cable) they start at less then £10
