They may - but, as I said, what most people understand by "taking a shower" relates to a flow rate of 10-15 litres/.minute.Much, much longer than that, they use a fine spray.
They need their own separate circuit(s), and that's assuming the supply to the site is suitable for adding such a large load.The anticipated total load will be approx 6000W from the heaters
It has never been appropriate to connect 3kW+ fixed heating appliances to a ring final circuit, even when such things were actually part of the Wiring Regulations back in the 14th edition during the 1970s.but I admit to being s little out of date with the passage of time
If I've done my sums right, then to heat 10 L of water through 50 degrees (say from 20 to 70 degrees) with a 1,300 W heater should theoretically take about 27 minutes - but that time would obviously reduce if one used gas in addition to the 1,300 W of electrical heating.
Thousands upon thousands of touring caravans and motorhomes have / do run with such HW tanks and people shower in them quite happily. It needs users to operate a 'wet' 'soap' and 'rinse' system, so not a continuous stream of water, but we used to cope well with it when we had such a system. (Cold water barrel - external - was no more than 40 litres as was the waste tank).
Ours was 850W/1300W electric and one could run gas at the same time to reheat quicker still if desired. Water was at 70C.
More than adequate as a shower when mixed with cold via the DC pump. We could shower one after the other (first towelled off and dressed before second undressed to shower giving the HW some 'recovery' on electric only).
The camping shower I had was a poly bag, clear one side & black the other. A fill cap (rather like a hot water bottle) and a short tube/tap/spray head.
I obviously cannot argue with your observation, but the fact is that raising the temp of 1 L of water by 85 °C with a 3,000 W heater requires a bit more than double the amount of time that you observed - specifically about 118.7 seconds (fractionally under 2 minutes)I always struggle with these calculations. I've just measured 1L of water into the kettle, it took 53 seconds to raise from cold tap to clicking off, in the absense of a digital sensor I'll make the guess it's a rise of 85-90º at ~3KW. All things being equal, it should boil 10L in 530 seconds/<9 minutes.
Again, although I can't disagree with your arithmetic (based on what you observed), to heat 10L of water by 50 °C with a 1,300 W heater requires a bit more than double what you have calculated, namely about 26 min and 51.5 secs (which I previously called "about 27 mins")..Ergo (3000/1300) x (50/85) x 530 = 719 seconds/12 minutes.
Quite so, and I can think of only one possible explanation for your 'misleading' observations, very similar to our recent discussion about the situation in which an immersion heater in a DHW cylinder is controlled by a thermostat near the top of the cylinder ...Yes I know the rules of physics... yada yada yada.
Hmmm. Well, my observations are certainly very different from yours, with my kettle taking appreciably longer to heat the water than calculation indicates - presumably due to 'heat losses' (whereas yours seemed to heat the water in under half of the calculated time!)!Al;though, as I said,I can think of no other explanation for your observation, I'm off to '#do the experiment', and will report back fairly soon
Thinking a bit more about this, it would seem that what I experienced with an ancient "2 kW" kettle, with minimal insulation, was probably about right - in that it took around 20% longer to heat up by a certain amount than the Laws of Physics say should have been the case.Why my experiences are so different from yours, both in absolute terms and in comparison with the theoretical amount of heat energy required is very far from clear - at least to me
Well the manufacturers of the unit I used to have reckon 30 minutes-ish on electric or gas only (1500W). 16 minutes if both used (2800 W).Ergo (3000/1300) x (50/85) x 530 = 719 seconds/12 minutes.
The accepted fix for that (the pipe was double-wall stuff that had an air gap for "insulation") was to use large bore Armaflex insulation around the external pipe (12mm thick iirc). Worked quite well. Mine fed from the fire to the front lounge vents. The bathroom stayed inside the bed base. Bathrooms invariably needed supplementary heating I found.Mine was blown air heated, but the blown air pipe, went under the caravan (terrible idea), so by the time the air arrived in the bathroom it was cold. My fix was to do away with the heat wasting underfloor pipe entirely, and replace it with an outlet blowing into the bathroom door.
That probably bears out what happens in practice, if my memory serves me.
Note the gas takes slightly longer than the electric due to inefficiency/losses from the flue.
They appear to be saying that it will heat 10 litres of water from15 °C to 70 °C in 29 or 30 minutes using the electricity-only mode (I presume 1,300 W, the higher of the two electrical powers apparently available.Well the manufacturers of the unit I used to have reckon 30 minutes-ish on electric or gas only (1500W). 16 minutes if both used (2800 W).
@SUNRAY ... we never got to the bottom of what went wrong with your experiment.So, as one would expect, the Laws of Physics are correct, per my initial post about this, but there is something very wrong about the experiment SUNRAY did to arrive at a very different suggested answer.
