I have installed a three zone system - simple question, I know how to balance the system, but not sure whether I should do each zone seperately, or the entire system with all zones fully on?
I also need a hint about balancing DHW - I have a fourth valve which supplies DHW, via 22mm - clearly, i need to reduce the flow to the tank, if heating is to operate correctly. Cannot find a 22mm in-line lockshield, so I will use a 22mm gate valve with the handle removed. But how much do I close it by? System has an automatic bypass (currently set to 0.4 bar), so possibly - DHW only on, and close valve until just before the bypass operates? Or is this too far?
Any advice gratefully received.
