Radiator feed order from boiler
Boiler is a Potterton Suprima 50
The maximum flow temperature you give is only 58°C. What do you have the temperature control set to on the boiler? (Min=55°C, Max=82°C)? Do you have it turned down so the water from the Hot taps is not too hot?.
Boiler thermostat is set to approx ¾, doesn't have any temperature markings on it. Minimum is approx 10 o'clock, maximum is approx 8 o'clock. I have it set to approx 5 o'clock position.
That's about 74°C, if my calculations are correct.
Is it always at this setting or have you turned it down for the summer? If you have a separate thermostat on your HW cylinder to control the HW temperature, there is no real need to turn the boiler down in the summer. But if you can only control the HW temperature by turning the boiler stat down, your setting is understandable.
Have you measured the flow and return temperatures at the boiler? This will give an indication of what you should get at each radiator.
It's always at this.
HW Cylinder has a separate thermostat, set at 60 degrees C.
Not had heating on since taking the original reads. As soon as we need heating I'll checks temps. Is my boiler thermostat set too low then? I think I read on here once that the ideally it should be about ¾, this gives best efficiency or something?
Thanks again for all your help.
