Radiator hot in the morning, cold in the evening
Did you do what I suggested about turning off ALL the other radiators and seeing how hot throughout the day the problem radiator gets? Ensuring the TRV is fully open and the lockshield is open a good amount too?
Not yet, I'll have to do that on the weekend. What am I looking for it to tell me, as the rad has the ability to get hot, just not in the evening?
We are looking to see if it stays hot all the time when the room is cold enough to require heat. Then when your satisfied that it constantly heats up as/when it should, turn on another radiator one at a time. Wait a good few hours or even better the next day, ensuring the problem radiator isn't affected before switching on each additional radiator.
Do you have a wireless thermostat btw? If not then the last radiator to turn back on, would be where the thermostat is located. This way there should be a call for heat as that room should be cold enough (assuming the set point is higher than that rooms temp).
Thanks - I have a wireless thermostat, which we typically keep in the living room
