Radiator not heating up.
20 Jul 2020
I have one radiator in my hall that is not heating up, looking through posts here it could be blocked but also could be a balancing issue which I'll check first. However the valve that has a spigot on it, how do I close that and not redirect water out the tailpipe.
Cheers guys.
First check both valves are on,then turn rest of your rads off and put the heating on ,it may be air .
Ok, thing is, only the bedrrom rads that have TRVs, the rest are like the ones in the pic. I know I need to pop off the cap turn the spindle but just to make sure that by open/closing the valve wont redirect wate out the tailpipes?
1. The valve on the right of your radiator is what is known as a wheel head valve. You should be able to turn it open and closed without removing the while plastic cap.
2. The valve on the left is a lock-shield valve:
2.1 You would have to remove the white plastic cap to turn the spindle with a spanner / grips to open or close it.
2.2 If you do open or close it, start by closing it fully (turn clockwise looking down) and count the number of 1/8 turns needed to close it. It can then be reopened the same number of 1/8 turns to maintain the balance of your central heating system.
2.3 Opening it will not let water out of the drain off cock. You will probably see a square bolt head inside the drain spigot, which is what you undo to drain the system.
