Hi all,
Hoping I may be able to get some help on this.... I've had an extra bedroom put on the side of my house. The plumber who installed the radiator for me did the radiator and went home.
Problem is, that I think the radiator has been connected on the wrong side of the motorised valve. The radiator gets hot when the hot water is on, but the heating is off i.e. the hot water flowing to the cylinder coil is also going through this radiator too! It's also worth pointing out that the radiator works correctly when the heating is on.
Could I add another morotised valve (Connected to the other motorised valve so they will work in tandem) to shut off the flow to the radiator? Or, do I need to get a different plumber to re-do the job?
Thanks,
Andy.
Thanks,
Andy.
