- Joined
- 7 May 2018
- Messages
- 12
- Reaction score
- 0
- Country
Erm ..... Nope ... don't agree. Maybe with mechanical threads in other engineering areas but not where a water/gas seal is required in plumbing/gas work.
Hang on. I think you are responding to my post out of context.
I haven't denounced the use of PTFE tape in producing a seal. I do it frequently. In fact I pretty much agree with everything you've said and would add that, as this thread is about radiator tails, most radiator tail manufacturers recommend PTFE tape to seal their products.
I was responding to Dan Robinson who was going beyond denouncing PTFE as a seal and denouncing it's use at all.
PTFE tape in plumbing was originally introduced as a thread lubricant. That is a simple fact. And if you don't understand this then you are missing out on a very important part of it's function.
Now I'm sure that the world is full of DIYers who try to use PTFE tape as an alternative to actually compressing the gasket or olive. But used properly in a compression fitting, PTFE tape significantly improved the controllability of the compression applied at the point where it counts.
Is there anything in that that you can rationally disagree with?
