Hello All,
Your advice please!!
3 radiators cold downstair cold including feed pipe. The same upstairs 3 radiator cold too. The system is an oil feed system with expansion tank in the loft. When the system first switches on there is a popping/banging noise as-though there is air circulating. I had the oil boiler serviced in April and the engineer said he had noticed a noise and recommended at some point adding some Fernox MB1 if it bother us.
So approx 50% of the radiators, including the feed pipes in the house are cold and the system is noisey when first switched on.
I've tried bleeding the rads and water does flow. I checked the small tank in the loft (expansion tank??) does have water in it but it doesn't look great!
The heating has two zones (up and downstair), two blockages???
Cheers,
Mark
