radiators constantly hot and cylinder not working properly
22 Dec 2007
can someone help. I have an hercal coil indirect cylinder that is approx 9 years old. There are two pipes on the side, from what i have read the top pipe is meant to be hot and the bottom one cold. They are both hot is this meant to be? There is also a problem with the radiators they are constantly hot when the thermostat is off and on heating only. The last problem is that the over flow pipe is constantly dripping.
is this something that i can sort out with a bit of guidance or do i have to call a man in lol
cheers
sorry i meant to say that the radiators are constantly hot even though the thermostat is on water only not heating only...
Incorrect. What the f*** have you been reading?
Yes. One will be marginally less skin-liftingly hot than the other.
Assuming that you mean 'on hot water only', then you might have a motorised valve that's not fully closing.
Depending on which cistern is overflowing, and which cistern is higher than the other, the fix could range from very cheap to very expensive.
You can do it, but you need a crash course in heating and plumbing.
Separate the problems out and deal with each one as a project you can undertake. Search the forum for similar problems and learn from the posts that have been made. Read the Wiki for some background knowledge and terminology. Then come back here when you've got your spanners out.
