right-oh....
Firstly, how has the boiler behaved since you switched the heating off???
Are you sure the actuator is on correctly??
To check operation, turn off the boiler at on/off switch and leave off untill cold..... Switch it back on and run the hot tap, when boiler fires up feel the flow pipe, ( this will be 22mm and at the extreme left hand side.... the one with the pressure guage).... If the pipe starts to get hot, then the div/valve is still passing (a small amount of heat is ok but not too much)....
A few more things to try, but let me know about this first....
Martin
Martin
