Our bedroom is on the end of our house (two external walls) and has a large sash wiindow and a glazed door to the garden (both single glazed). For the record, we are in a conservation area so new windows and doors for the house are prohibitavely expensive.
We have a largish radiator in the room (1.4m x 0.7m , K1) but, even when it is running nice and hot, the room is always cold. A quick online calculation suggests that the radiator is not large enough for the room (needs about 5500 BTUs and only gets 3900 BTUs from this radiator)
A friend is upgrading his central heating system and is throwing out a perfectly good k2 rad which is a 1.8m x 0.6m k2 (10000 BTUs). This will more than double the heat output which is probably a lot more than I need.
I've calculated all the other radiator powers (in kw) and out boiler does have just enough extra oomph to drive the additional load of this new radiator. Are there any other issues that might occur if I fit such a large radiator in this room?
Cheers,
iep
Cheers,
iep
