I have recently moved into a new home and replaced some of the radiators. A couple of them are larger double panels compared to what they originally were. In total, 3 large type 21's, 2 large type 22's and 2 small ones.
It is a regular vented system with a cylinder and tank in loft.
Now it seems the radiators do not get hot enough. They are hot, but compared to where I used to live, the radiators used to get too hot to touch, where as I can touch the new ones comfortably. As a result the rooms takes forever to warm up, and never really reaches the desired temp of 20-21c.
So the most obvious cause to my untrained mind would be the boiler doesn't pack enough power to deal with the new rads. It is an old boiler, possibly 15-20 years old.
But could it be something that could be a quick fix in the short term?
I have bled all the rads, and do so regularly.
I have turned the pump up from 2 to 3. This has helped slightly, but not enough.
Given the cost of moving home etc, I don't really want to replace the boiler right away, so if anyone has any alternative suggestions on how to improve the situation, I would be grateful.
