Rail and stile bits. Cant find anywhere :(
The C157 set is available in 1/4in, 8mm and 1/2in shank versions. I'd go for the biggest shank my router will support simply because on 1/4in shank tools it is relatively easy to overfeed and bend the cutter shanks on this type of cutter if you don't take care. It is actually two tool bodies and a bearing mounted on a single shank. To make the second cut the order of the cutters is reversed on the shank. The cutter comes with a manual explaining how to do this, but there is also a video here and if you watch at around 1:35 you will see a cutter being reversed in that way for the second cut
Yes i see, so its just 1 router piece that does both cuts for the doors. I will purchase the C157 however what is the difference between the bevel combination set and the bevel easy set.
On the bevel combi you split the tool and alter the position of the cutters to make the second cut. On the bevel easy you don't need to do that, all you do is to change the height of the cutter in the router table, but you do pay for the convenience (about an extra £15 or so) and you are limited to 1/2in shank only on the easy.
