If you use the type of brackets I linked to then the posts are not below ground level. They are bolted to the bottom of the post and these are on top of your foundation. You cast a concrete pad foundation and sit the brackets on top, or the second one I linked to you cast It in place with the concrete haunch up at an angle to prevent the post end siting in water.
The type of concrete you will end up casting will not be waterproof.
Waterproof concrete is for retaining walls or swimming pool walls and the like and is packed with reinforcement. You will not achieve that in your garden.
