Raising my bath 5-10mm
I bought one of these kits, it's expensive but did the job (walls weren't straight on one end of bath).
I prefilled the big gap with silicone, let that set a couple of days then used the Bath Seal kit to trim it up.
Been on a few years now, easy to clean as well.
Yes.It was.Otherwise you would not be in this situation.Maybe it is a flexi cheap and nasty bath too...Sort it properly or it will rot your floor and ceiling.
Thank you. The bath is a reasonably nice one. Just had a plumber round for another job who suggested it needs to be lowered, layer of silicon, raised up to stick it on the base of the tiles then raised up. Then a strip to seal the gap, similar to what others here have suggested. She said she'd sort it for me but then the 1hr shower installation took 5 hrs so I'm back to doing it myself
Those baths were supplied with angle brackets to fix it to the wall, if they have been fitted you will struggle to move it up or down.
Mystery solved...
So I don't fully understand what's going on but the 5 legs (1 central) aren't all touching the floor so when someone gets in it moves/flexes until it does. A few turns of the bolts and it's solid. I raised it about 5mm all around which will make sealing a lot easier. Unfortunate noticed a slight leak in the drainage pipe so that's the next job...
Thanks everyone for the advice!
