After some advice regarding an area of brickwork that I am looking to re-point around my house. Not a big area, around a front porch.
I used a diamond blade on an angle grinder to clean out the old mortar. Any areas that the blade couldn't access such as corners, i've used a chisel to clean out to approx 20mm depth. The grinder does a good job at removing the mortar, albeit a messy job. On close inspection, on the underside of some of the brick there remains a thin layer of old but stable mortar - 1 or 2mm. There's plenty of room to pack in new mortar when it comes to re-pointing but my question is, do I need to chisel out the 1-2mm of mortar that remains on the underside of some of the brick?
I want to do it right but equally, don't want to spend a load of time manually chiseling if it's not necessary.
Last question is around new mortar. I have Blue Circle mastercrete cement. Understand it is decent for repointing as it is a portland / limestone mix. I was going to mix 1 part cement to 4 parts builders sand. Does that sound reasonable?
Cheers.
Cheers.
