Repointing Victorian brickwork: are they using the right mortar?
This is a picture of the back, where they've replaced some bricks (the dustier-looking ones are the ones they've put in). As you can see, they've started repointing. Can you see from this picture? https://drive.google.com/file/d/1l-uVm8h9HjWXPMzNVe1uurs9WXLuGO6K/view?usp=sharing
you should be pointing with hydraulic lime mortar, this is original, (circled red), their pointing is clearly not hydraulic lime (circled green), it looks like there have been been a number of poor repairs over the years, this may add to the confusion.
you need to stop them completing further work
Why are you having the red bricks repointed?
Those bricks look quite eroded, and the mortar looks sound but with many shrinkage cracks. This indicates that the mortar is cement and it was too strong, this causes the bricks to erode and the joints to crack.
As for lime and cement mortar, lime can be added to a cement mortar to aid workability, and its still a cement mortar. Cement can't be added to a lime mortar.
the red bricks look like they have been repointed in the past with cement mortar instead of hydraulic lime which the house would have been built with
Again, thanks for your replies - very helpful. The reason for getting the red bricks repointed is that the front of the house had been patched here and there and then painted several times. Various types of fillers had been used. It was a bit of a mess.
hopefully we have helped, and fingers crossed you can get it rectified with little additional expense.
The bricks are originally built (mortared) with lime mortar, they cannot be pointed with cement because the lime mortar underneath cannot breathe through it, this causes moisture retention in the brick and they will start spalling next winter.. STOP them now and make sure they dig out everything they've done and use a non-cement based (lime) pointing mortar...
Thanks again for your advice. Another quick question... Can they justify referring to cement mortar with a lime additive as 'lime mortar'? The comments by sxturbo and ^woody^ suggest they can't. Just checking I'm reading you correctly.
No they can't, 2x different things that just so happen to have one ingredient the same. It's like saying egg and bacon is the same as poached egg and avocado.
They've stopped work but it's blown up into an argument. They argue that I should have specified I wanted hydraulic lime, and that their mix containing cement and lime can be described as a 'lime mortar'. I've said I need to get an independent opinion - either a trader or a surveyor - before they continue. They argue their mix is approved by architects and building firms.
I'll see if I can get any advice from trading standards. I have already paid for the pointing on the front of the house, which was done a few weeks ago. I haven't paid for the pointing on the back, which is still in progress.
