When we moved into our house 5mths ago, we found that the heating was pretty rubbish. Many of the TRVs were broken, some Lockshield valves were seized, rads were not heating up uniformly, etc. Also, we only have TRVs on about 60% of the rads making individual room control a bit tricky.
Now that the weather is warm enough, I'm planning on giving the rads a bit of TLC. The plan was as follows:
1. Part drain some of the system and add some Sentinel X400 to the system
2. Run the heating for 10-15mins over a few days to pump it round and give it chance to work
3. After a week or so, drain the radiator circuit
4. One by one, remove each radiator, take it into the garden and flush it out with a hose
5. Replace TRV / Lockshield valves as appropriate
Simple plan made harder by the fact that we have a Range FlowMax system and draining the rads & tank means we have no hot water until such a point as it's all put back together and re-filled.
As it takes about 1.5hrs to empty the whole system and just as long to re-fill, I don't really have much time to take off each rad, flush it out and replace the valves. Wifey will not tolerate no hot water in an evening (wimp I know!) and I don't want to be emptying / re-filling the system multiple times as I get around the 16 radiators in the house.
Working on my own and not knowing if I'm going to find any problems as I remove each valve, I don't know how much time this little task is going to take...
So, I'm calling on any FlowMax experts that might be out there to ask for advice. Is there a way of isolating the radiator flow circuit form the tank store, so I can take my time???
There's no obvious cut-off / service valves in the airing cupboard, but underneath, the pump does have them. This means I can cut off the flow side, but I dont' know if there's a way of isolating the return.
Would the system have a one-way valve on the return anyway preventing backwards flow? If it did, would it be safe to turn off the service valves at the pump, empty the rads, do my work over the period of a few days / a week (without therefore affecting the hot water side), then once I'm done, empty the remaiing water in the tank before re-filling the system?
Any advice would be much appreciated.
Thanks,
Mark
Thanks,
Mark
