The amount of gas you use is propional to the amount of heat you are using. The boiler modulated over a ratio of about 4:1.
There is a small loss of efficiency on heating if the minimum power output exceeds the heat demand and that causes cycling and slightly less overall efficiency.
I would not advise fitting a larger combi than necessary if the heating load is smaller.
Having said that 14 li/min is only one and a half average taps!
But heating is usually over 80% of the annual load.
Tony
Tony
