Good morning all
This rayburn thats haunting me is still overheating, causing a reset stat to trip on its control panel. Unfortunately it has to be manually reset, which is a bore.
The scenario....switch the boiler on, pump starts, all jolly and cosy.
When the boiler time switches off, water in the boiler naturally gets hot, reset deploys.
The boiler is sending a pump overrun signal to the wiring centre in the loft, so all ok there.
However, the pump stops running because the signal is blocked by something in the circuit - hence the overheating. It is an S plan system.
Would it be in order for me to take a live from the boiler and link it to the pump live - to keep it running for as long as the boiler overrun stat tells it to, or am I giving myself other problems?
As you can tell, the theory is fine but I don't really know what to do for the best.
Good day all! John and thanks for reading.
