I have a Raybun Royal that has a bubble conversion. I have serviced it myself for the last 14 years and have had no problems, until now, and I would appreciate some suggestions.
The kerosene is fresh.
The filter on the tank outlet is clean.
The control valve is an OCI. I have stripped it down and the metering slot is clear.
The filter for the control valve is clean.
I have checked the fuel level in the float chamber and it is correct.
The fuel level is the correct hight in relation to the base of the burner.
The pipes running to the burner are clear.
I have carried out a flow test and on low and high settings the flow is as it should be.
The burner lights without any drama, and quickly gets up to approx 140-150 degrees c on level 3. There is a nice blue flame.
However after approx 10 hours the temperature starts to drop, the vapouriser starts to cool and then it goes out. The oil feed going into the burner is a bit coaked up following this event. Repeated 4 times and no improvement.
Flue seems to be unobstructed with a good draw.
