- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Opinions please!
Old couple in house built 1954, which needs a rewire. Waiting for council to get their finger out and OK the grant. Been waiting already 3 years so in mean time there is a problem with nuisance tripping of RCD which is under the stairs and impossible for female to get to (only one leg) and hard for male to get to.
Cure 1 is to change RCD to auto resetting RCD about £300 for unit.
Cure 2 is to remove RCD and fit RBCO’s on those circuits.
The supply is TN-C-S (PME).
Using his stick the male can just about reset the RCD so he should be able to reset RCBO but unlikely female will be able to re-set them. Once rewired one would hope the RCBO’s or auto reset RCD could still be used but because once rewired one would expect duel RCD’s at least either one would be manual or need to spend another £300 for second auto RCD.
If male dies before female then auto RCD’s will be only option unless the whole consumer unit is re-sited.
I know auto RCD’s exist but never used one. Not sure how good or bad they are.
Ideal would be for council to get their finger out but considering how long it’s been already seems one of them will need to die first.
The house was converted 3 years ago to allow the lady of the house to live there with one leg and a wet room was built under 16th Edition regulations which resulted in single RCD protecting some circuits (Not sockets except for those in garage which would be used for lawn mower). So showers, under floor electric heating, loft conversion, central heating and garage are about only items protected. Down-stairs shower is not electric but boiler is still on protected side.
So which option or third and why? Couldn’t give a dam about Part P if council got their finger out there would be no problem. And last time charges were waved anyway because both are disabled. Two people could do the work. Me or my son. Both qualified so please don’t bother about testing etc. It is in some ways just temporary until council moves but one would hope parts can be reused.
