RCBO is better due to it only taking down the 1 circuit, a RCD will take down everything thats on the RCD side.
An RCBO is an RCD
Regards
Pedantic- An RCBO has the functionality of a RCD but control only one circuit.
So teaching you to suck eggs, would you care to accept that 6 x RCBO's are better than 6 x MCB's on a RCD rail
Sorry no as in at least one place (caravan) this would not be permitted as the RCBO does not switch off all live supplies it only switches off the line. Yes I know there are some specials that will but not the type fitted in normal consumer unit.
Although in many cases it may be better because of tripping problems it can't be done in all cases.
Sorry if I am posting too often. I can't help myself!
I have just been reading through some old posts. And I read that the 17th edition requires un-earthed lighting circuits to be RCD protected.
No! 17th edition does not allow unearthed lighting full stop.
522.6.x covers the cable installation and it will be near impossible to comply with no earth in a cable.
411.3.1.1 Protective earthing
. . . A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a lampholder having no exposed-conductive-parts and suspended from such a point.
Note it says lamp holder not ceiling rose. The rose must be earthed.
In other words not required in the flex dropping down to each lamp.
But
Electrical Safety Council do seem to allow the practice.
416.2.4 ceiling rose is about the only item where you don’t need a tool for access.
And because a lamp holder will normally have a bulb fitted it is about the only socket allowed without a shutter over the pins.
What you are asking is what are the regulations for when you break the regulations? And of course there are non.
It is like asking:- “Is it true if my seat belt is missing I should not exceed 30 MPH.”
Possibly. You can always ask. Changing a single MCB to an RCBO just takes a few minutes. You may as well get a spark to do the whole lot for you - fitting and testing.
Unfortunately though, this could be a can of worms!
Of course it will he can’t sign it off. He was lucky to get board changed and most sparks will consider it is not worth the hassle involved and will just say no.
You may get one who thinks he is doing you a favour but it is apparent it is not a temp fix as already you have know about the fault for a couple of years.
