Not all RCBO's will test in isolation, at source...
Read his other posts and you'll see why.What on earth made you think you were competent to do this work in the first place?
I presume he is reffering to the MEM RCBO pods (which are availible either already combined with a MCB or seperate for field fitting), these monitor the live by running the outgoing live core through the current transformer. Therefore if you test by probing the output terminal they don't trip.Not sure where you are going with this? A 30mA RCD is a 30mA RCD which I don't see why you can't test in isolation at source - isolation meaning that the outgoing wires to the circuit are disconnected. If it fails to trip then it is a fail and requires replaced.
Could you explain why you've fitted anything into a bathroom without a CPC?Having just fitted some new bathroom lights for a customer, I've installed an rcbo on the existing lighting circuit, which doesn't have a cpc.
Are you Tonyx?ANYTHING without a cpc?
Are you saying that Tonyx (or you) has fitted these?SELV transformer? Class 2 device?
