- Joined
- 11 Jan 2004
- Messages
- 43,883
- Reaction score
- 2,873
- Country
I can see the spark who put in those RCD's Couldn't Be Arsed to put them in alphabetical order.
Careful, there - 'twas me who 'put them in'I can see the spark who put in those RCD's Couldn't Be Arsed to put them in alphabetical order.
The magnet absolutely stayed powered until the lever was moved to 'OFF', however when wired correctly the magnet released with the load. The RCD was marked correctly as to which was supply and load.I think many are still like that - all of mine certainly are. It's sometimes possible to 'just reset' but, moreoften-than-not, it's necessary to 'push them right down' before they will reset.
Leaving the electronics 'powered' after the device has tripped (hence the load disconnected) would surely not result in the release magnet remaining powered (unless the device were faulty), would it?
Kind Regards, John
I can't argue with your experience, but that sounds bizarre/wrong, since it makes little sense. Why should the actuating magnet remain powered after the load (and, together with it, any faults) been disconnected by the device - unless, of course, the electronics were faulty?The magnet absolutely stayed powered until the lever was moved to 'OFF', however when wired correctly the magnet released with the load. The RCD was marked correctly as to which was supply and load.
No No. When connected correctly [power to 'in' and load from 'out'] the device will trip correctly and the electronics & magnet will lose power to release correctly. However when powered from the wrong side [power to 'out' and load from'in'] the device will trip correctly and isolate the load correctly but the electronics is still powered [directly from the incoming power] and the magnet is still powered, bootstrapped I guess.I can't argue with your experience, but that sounds bizarre/wrong, since it makes little sense. Why should the actuating magnet remain powered after the load (and, together with it, any faults) been disconnected by the device - unless, of course, the electronics were faulty?
Kind Regards, John
Yes - but if the (still powered) electronic circuitry is working correctly, it should switch off activation of the magnet as soon as the L-N current imbalance, due to a fault, disappears because the load had been disconnected from the supply (hence was not drawing any current at all, 'unbalanced' or otherwise), shouldn't it?No No. When connected correctly [power to 'in' and load from 'out'] the device will trip correctly and the electronics & magnet will lose power to release correctly. However when powered from the wrong side [power to 'out' and load from'in'] the device will trip correctly and isolate the load correctly but the electronics is still powered [directly from the incoming power] and the magnet is still powered, bootstrapped I guess.
I can only guess it's bootstrapped to force release, then power going off will automatically release the magnet. It seems like a fairly obvious solution to me.Yes - but if the (still powered) electronic circuitry is working correctly, it should switch off activation of the magnet as soon as the L-N current imbalance, due to a fault, disappears because the load had been disconnected from the supply (hence was not drawing any current at all, 'unbalanced' or otherwise), shouldn't it?
Kind Regards, John
You mean 'electronically latched'? If so, then, yes, that would result in the behaviour you describe. However, although I may be missing something, I don't see anything particularly 'obvious' about doing it that way, since there would never be a need for the 'magnet'/solenoid to remain activated after it has mechanically triggered the trip mechanism.I can only guess it's bootstrapped to force release, then power going off will automatically release the magnet. It seems like a fairly obvious solution to me.
I'm sure you're right in most, if not all, cases (today), and some manufacturers actually say that explicitly. However, it's not impossible that there are, or have been in the past, some for which that is less true, for reasons such as SUNRAY has postulated.I'm still going to go with "doesn't matter". If it mattered surely it would be clearly labeled so the manufacturer could avoid liability from incorrect use.
