Hi - I currently have a 6mm radial (32MCB) to a 45amp cooker isolation switch (above worktop level) with a 6mm connection into a CCU. The radial runs under a timber floor, into a skirting duct then is clipped to the wall behind the units - No RCD protection. I want to replace the CCU with a duel connection plate then run 2 X 4mm T&E to 2no surface mounted back boxes (positioned on the wall behind the units accessed by a removable panel in the back of the kitchen base unit) for a 3kw induction hob with plug and 2.6kw oven with plug. Question is unswitched single socket outlets or cut plugs off and connect via RCD FC Units?
