I Am working on a new build house located on a farm. The REC supply is I beleive to be a TT supply converted to TN-C-S. (the supply is a pole fed supply with an earth spike at the base of the pole but a PME terminal is provided at the cutout) The supply to the new house will be provided by cutting the tails and putting them into a 100A D.P. Henly block, then taking new tails to 1way metal clad consumer unit (with 100A D.P. Main Switch and a 63A MCB). This will supply a 35mm2 3 core SWA cable. The SWA is then connected to the new Consumer unit in the house. Does the main switch at the intake position need to be an RCD main switch? or can I just fit an RCD main switch in the new CCU in the house to save a trek to the intake position? or can I just fit a standard split load CCU? The existing installation for the farm is protected by an RCD main switch but I don't know if this is purely because it is a farm supply or if it is because supply type. Unfortunatly I don't know what the external Earth Fault Loop Impedence value is.
Here is a picture of the cutout:
(the earth is only 10mm2 but I will be upgrading to 16mm2 when I make the alterations)
