Farm Mains Upgrade
I know fuses would be better, but where all this is located it needs to be IP rated as the rain could possibly blow in. I was going to use an IP Dist board to house it all.
Couldn't you get suitably IP-rated enclosures that would be able to house fuses? I've never had reason to look for such things, but would be surprised if they don't exist.
Kind Regards, John
Though if the area where the RCDs are is liable to getting wet, then the cutout & meter are at risk of the same, so the area should be waterproofed
Of course you can.
A suitably IP rated DB could have fuse carriers installed instead of MCBs.
All that's left to address is what to do if you need to open the door of the enclosure in the driving rain.
Of course you can.
Perhaps this is the way to do it then. Do hagar do one to fit in their IP VE type of dist board anyone know? Havn't googled it yet.
Re the rain, the building has a roof etc, but should really have double doors (like a garage really) but it doesn't. Its unlikely to get really wet, but could get 'damp'.
Put a normal board / switch fuses inside a sarel steel or grp enclosure.
