I have just had a quote from local spark for installation of new 9kW shower unit. He insists that he needs to supply / fit an additional "Shower CU" alongside my existing 12way consumer unit as I require an RCBO which cannot be fitted into my Contactum CU. My issue is that my CU has an 80A RCD covering the installation and plenty of spare capacity. Surely all I need is a 40A MCB to run the circuit. I have a rod (TT) earth which I'm told has 18ohm "loop".Also a 10mm T&E cable upgrade(which I understand the need for). Am I missing something here?
