RCD-protected circuit that is not on a separate breaker
Then I turn ON the second RCD and the loft sockets come up (all MCBs are still OFF). Is that normal?
No not normal, it would seem likely there is a fault, as @flameport says, but with my own house, can turn off all RCBO's and the freezers and fridge/freezers still work, and central heating still works, there are always exceptions to the rule, but seems more likely there is a fault.
Yes, but if you turn off all RCBOs AND MCBs surely nothing works? If something does then you have a similar problem!!!
Eric has a UPS.
Yes and as you rightly say this is why
Is not true, all RCBO's all isolators, and all MCB's off and 4 sockets and a FCU still works, and I feel I do have a problem as the button I need to press to switch it off has no provision to lock it off, but I also have a certificate to say it is compliant.
I am reasonably sure @RookieTony also has a problem, however there may be an overload device within the required 3 meters from the CU we are unaware of.
So all we can say is it requires investigation.
