That's what my memory says.Some include them in the product paperwork.
I struggle to see how a statement to the effect that "this toaster complies with the Low Voltage Directive" isn't pretty much the same as "this toaster is Low Voltage".I would suggest that it would be far less worrying (and far less potentially confusing) than would be the case if something were described as a "Low Voltage toaster", "Low Voltage oven", "Low voltage lamp", "Low Voltage toy" or whatever.
Your faith in the ability of people to know and understand things like that given their abilities regularly displayed here is touching, but I fear misguided.I don't think that Part P is particularly relevant. It is probably inevitable that it be written in terms of the 'official' definitions, and anyone who needs to read it will hopefully understand what those definitions are.
Indeed. My view is that, given how the vast majority of people/ consumers/ buyers would probably interpret it, no product designed for use at 'mains voltage' should be described (i.e. named/labelled) as a 'Low Voltage' product.I think my conclusion from what you are saying, whether or not there are items so marked, is that even the ones that are, i.e. lamps, should not be described as 'low voltage' either.
I've never suggested that. My belief is that the great majority of people will interpret "low voltage" as implying a voltage low enough not to (usually) be a significant threat to life, which would presumably encompass any of the voltages you mention.After all a 'low voltage toaster' could be any voltage in the range and so can the lamps. People assume they are 12V, so are we to accept that 'low voltage' only means 12V - not 6V, not 24V, not 49V?
That statement seems to indicate a lack of understanding of the different ways in which people regard what they consider to be 'small print' as compared with how they regard the primary 'name'/descriptor of a product.I struggle to see how a statement to the effect that "this toaster complies with the Low Voltage Directive" isn't pretty much the same as "this toaster is Low Voltage".
But they have to be.Indeed. My view is that, given how the vast majority of people/ consumers/ buyers would probably interpret it, no product designed for use at 'mains voltage' should be described (i.e. named/labelled) as a 'Low Voltage' product.
In popular culture, Darwin might have had something to say about the wisdom of dismissing product specifications and statements of regulatory compliance as "small print".That statement seems to indicate a lack of understanding of the different ways in which people regard what they consider to be 'small print' as compared with how they regard the primary 'name'/descriptor of a product.
I don't know about "have to be" - but, as I've said, thankfully they aren't described (to consumers/purchasers) as such.But they have to be.
Part P applies to any work whatsoever on fixed electrical cables or fixed electrical equipment located on the consumer’s side of the electricity supply meter, no matter who does the work.I don't think that Part P is particularly relevant.
Virtually everybody who posts here needs to read it.It is probably inevitable that it be written in terms of the 'official' definitions, and anyone who needs to read it will hopefully understand what those definitions are.
