- Joined
- 19 Jan 2005
- Messages
- 1,171
- Reaction score
- 41
- Country
Hi everyone and happy easter!
I'm doing a PIR next week in a house converted to flats and the supply from the cut out to my flat is in 16mm t and e, run in walls in the safe zones as far as I can tell.
My take on this is as the original install was not to 17th, then this would warrant a code 4 (not RCD protected, does not comply).
However, if the board was then upgraded to 17th, would the supply require rcd protection?? This seems to be at odds with the requirement not to have one RCD protecting the whole install....?
Your thoughts would be welcome!
SB
SB
