Depends how much current was flowing, the resistance/impedance of the circuit conductors and versus the resistance/impedance of the meter tails. If the meter tails etc are pretty short you may need to have quite a few amps flowing to get enough PD between the neutral and earth rails in the CU to cause enough current to flow through the N-E fault to cause the imballance (somewhere between 16 - 30mA).
As long as all your tests came out fine you are home dry
