hi guys ive just fitted a spilt load wirlex cu to replace and old cu the problem i have is the 80amp rcd is tripping constantly and wont even reset even when the protected mcbs are all off , ive even removed all wire to the mcbs on the protected side just leaving the rcd live and it still trips as i thought there may be an earth fault on one of the circuits .would you say its a possible rcd at fault many thanksin advance tim
