a kitchen has been run in a 6mm radial(no idea why 6mm) one side of the kitchen is the old red/black cable,the other is the newer brown/blue.
it looks like the kitchen is only a few years old and new sockets have been added to one side of the kitchen into the radial circuit,the rcd is a seperate unit to the consumer.
the problem the person is having is the rcd trips when the washer is plugged into the nearest socket (red black cable),but if anything else i:e toaster,kettle,it dos'nt trip,
so you would think problem with the washer,but if you plug the washer into the next socket along (same red black cable) using an extension cable the washer will go through a full cycle and the rcd dos'nt trip,i have had the socket off and changed it,all the connections are ok and can't see any other problems,
anyone any ideas please.
